Under Counter Cabinet Lights
  • canadamag
    • Nov 2004
    I am trying to install under counter cabinet lights (puck lights).
    The cabinets are already roughed in. Do I just wire all the rough wires to the transformers to complete the circuit. All of the cabinets but one have 2 wires coming out from them. Is there any paticular way I should start from?
    This is sort of after that fact type of installation. How do we make this aethsetically pleasing and still afford the protection it needs? I don't think it's possible but we will try. Are the transformer(s) within view? Can you hide the secondary circuits? What is the current draw on the secondaries? I need this to determine whether or not you can do what you want.
    • canadamag
      • Nov 2004
      There is enough room under the cabinets to hide the transformers and junction boxes.
        Just parallel the primaries from cabinet to cabinet and directly wire the secondaries to the lights.
        • canadamag
          • Nov 2004
          Then there was light!!!!!
          Thanks for your help. I was a bit confused because there was no power on any of the cables, there was a cable disconnected on the switch.
