I have a house that has brand new 100 amp electical service. Sometimes when the humidity is high outdoors moisture (water) accumulates in the bottom of the fuse panel. I know from inspection by a qualified electrician that the water is not coming from outside. I have observed it coming from the inside of the sheathing on the neutral wire coming from the meter box. I firmly believe it is condensation. Sometimes there will be no moisture/water after a driving rain and sometimes there will be some. Is this normal? I never looked for it in my old service and was wondering if the is normal. The moisture does not drip down through the panel but directly from this wire to the bottom of the panel. The basement where the panel is located is fairly cool.
