romex
  • jackal
    • Mar 2005
    romex
    Can I run romex(12/2 yellow) under my poer and beam house or do I need to put it in the gray pvc?
    thanks,
    jackal
    Ideally underground required type UF cable. This is meant for direct burial and is corrosion and sunlight resistant. Because romex is a cable assembly with an outer jacket it can't be installed in a long run in any kind of conduit. Short runs, <than four feet is ok for mechanical protection.
