electric stove wiring
  • tucsonjp
    • Aug 2003
    My mother-in-law just got an "almost new" electric stove from a friend who is remodeling her kitchen.
    The stove has a 4 prong plug, with 4 terminal screws on the back, but her kitchen has a 3 wire 220 recepticle.
    Can I simply use a three wire cord, connecting up the black, red and neutral? And if so is the stove grounded?
    The stove has a green ground screw on the back as well. Should I add a jumper from the ground to the neutral (white) wire.
    Thanks - John
  • 16x80
    • Jul 2003
    • 120
    tucsonjp
    Welcome to the Home Repair Forums
    As for your new style Connection you have. That is moving to be the standard in connections. What you need to do is buy your self a new 4 prong outlet and plug. The fourth wire is a secondary ground. Give it a go should be fairly easy for you.
    16x80
