I have two well pumps hooked up to my Square D 20 Amp Double Pole Circuit Breaker via a ROMEX® 12-2 NM-B with Ground Indoor Electrical Wire.
The problem is that once in a while the breaker will trip. I was told by the well guy that the breaker may need to be increased to 30 amps, but the wire is 12-2. Do I need to run 10-2 wire to go with the 30 amp breaker or will the 12-2 wire work?
I don't want to melt the wire and burn the house down.
Thanks
Thanks
