good morning, i am new to the forums[:I]. I have been looking on the internet to find out how to rewire a swag lamp. I have rewired other lamps w/ no problems. What i am having a problem with is the roller switch to turn the light off and on.
The salesperson at the shop told me to take the switch apart and divide the wire in middle so the screw could go between the wires. He then told me to cut one of the wires in half and place it on the side of the switch w/ the divider ( the divider goes between the cut wires, make sense). then to place the other side of the switch back on and tighten the screw. when i place the other side on, to sharp points go into the cut wire. I did all of this and the light doesn't come on
Can anybody tell me if i did something wrong[?].
I even checked the socket again and checked the wires and same w/ the plug. one thing i didn't do was make sure it worked before i cut the wire[^].
I am going back to the store tomorrow and see if the guy can help me, but thought i would try here first.
thanks
deb
. Can anybody tell me if i did something wrong[?].
thanks
deb
