Is there a way to check if a ballast has gone bad? I removed two very old florescent fixtures which had two blubs each and replaced with one fixture that holds 4 blubs. After installing, only two of the four blubs worked, I do believe the one ballast maybe bad. I have a few up in my barn but I have no idea if they're any good. Can anyone help? I have a multimeter and other electrical testings things. Had to replace my main breaker about six months ago($125.00 wow (
). I kinda know electrical but I make lots of notes and do allot of double checking cause of the terms used. So if someone does have a test suggestion please try to use simply wording.
Thanks
Pam
). I kinda know electrical but I make lots of notes and do allot of double checking cause of the terms used. So if someone does have a test suggestion please try to use simply wording. Thanks
Pam
