Outlet voltage
  • RedGreen
    • Dec 2005
    Outlet voltage
    I have two non-working outlets. I used my meter to check their voltage expecting to find none. Intead I found that one reads 43 volts and the other about 90 volts. They are on different circuits.
    any ideas??
    thanks
    If I can't fix it I'll screw it up so bad, nobody can.
  • lonestarheir
    • Jul 2005
    • 137
    Did you check the voltage to ground or to common? I am assuming that these are 110V outlets?
    Brandon
    Brandon
    • SSN596
      • May 2005
      • 136
      Any phantom reading like 43 or 90 volts is often caused by an open neutral. You need to stat inspecting the connections in each box on the circuit/
