I took out a wall to make a bigger bedroom. Problem - There were no ceiling lights installed in any of the bedrooms but they each have a wall switch to an outlet. When I took out the wall, the wires that ran to the wall switch had to be cut. Now I have a hot wire on the outside wall (capped off, of course) and dead wires on the inside wall where the switch runs to. Going into the attic to bring the hot wire to the dead one is not possible. Now what and is a diagram available on how to connect wires so that the switch and the outlets both work?
Remodling needs rewiring
