So the supply cable actually has a ground wire run with it or externally?
What's important to know is where the other end of this ground wire is landed. If this circuit doesn't have a ground wire comming into the main panel then where is it getting it's ground from. Any ground wire added after the fact should be run all the way back to the main panel
