Just moved into on small apartment building in a complex of several same units, i.e.-small houses. Lights are flickering throughout the apartment on minimal load with no seeming connection between load, appliance and flickering,-can occur when only one light is turned on. Flickering seems to diminish as light or appliance remains on.
What is the general probabliity this is a utility problem versus a bad wiring problem or connection between the two.
I need to isolate the problem to proceed. Can use VOM and have basic electrical/electronics knowledge.
Will the utili. company help with this; what do they usually do if I complain?
