220 volt three way switch?
  • Dragon Fyre
    • Jul 2007
    I am looking to set up a 220 volt woodworking vacuum system on a three way switched outlet.
    Is that possible, and if so, is there a special switch for 220?
    Thanks!
    I wouldn't use a three way to switch a 240 volt load. better way is to get a 30 amp contactor with a 120 volt operating coil. use the 120 volt as in any other conventional three way circuit to switch the coil of the contactor.
    • Dragon Fyre
      • Jul 2007
      Thanks for the prompt reply HayZee518! I'll give it a try. Thanks.
