I'm adding up all my essential power needs in order to get the right sized generator and from what I understand I need to keep a running total of the 'running' and 'surge' power requirements of the various fixtures or systems. Then, when I'm done listing all the needed draws, in both categories, add the two sums together in order to get the final number.
When allowing for the necessary 'surge' power needed, couldn't I just allow for the largest draw since that will take care of any lesser number?
also
I have an indirect hook-up between my 40 gal. SuperStor hot water storage tank (16 years old) and my Weil-Mclain 68 oil-fired boiler. About how much power should I allow for heating the water?
Thank you for your help,
also
