What type of dimmer switch?
  • tgif
    • Nov 2007
    I want to use a dimmer switch to control the brightness of some halogen lights. The bulbs are marked: Philips Twistline Alu 50w 120v 250 F5.
    The fixture is not labeled with anything.
    Do these bulbs require a dimmer switch with a magnetic or electronic transformer? Or do I use a dimmer made for incandesant lighting?
    Thanks for the continuing advice.
    the bulbs are marked 120 volt so just about any type of dimmer will work. if the halogens were part of a low voltage circuit then a special dimmer would be needed because of the low voltage transformer.
