Separate breaker box for second floor
  • kev
    • Jan 2008
    I have a 100 year old house. The second floor has old/unsafe wiring. I want to install a separate "box" with breakers for everything on the 2nd floor. My sons and I will rewire the entire floor. My goal is a safe house, and the ability to turn off 2nd floor with one switch (when boys leave home), Do I have to have licensed electrician do this? Is it even possible to do this? HELP!!
  • Speedy Petey
    • Nov 2006
    • 214
    It certainly is possible, if you know the codes involved.
    If you need a license or not is a local requirement. Check with your local building office.
    You definitely should know what you are doing if you intend to do it yourself.
