Kitchen plugs
  • ryandebny
    • Jan 2008
    • 37
    Kitchen plugs
    If I want counter outlets for my kitchen, would I be better using 12-2 with a 15amp breaker. I plan on setting up 3 outlets on the circuit, the first outlet would be a GFI will any GFI do
  • Speedy Petey
    • Nov 2006
    • 214
    No, you would use a 20A breaker with #12.
    Besides, 20A circuits are code required for kitchen counter receptacle circuits.
    You can use either 15A or 20A GFI devices. 15A is fine though. No need for 20A receptacles on a circuit like this.
    I know this sounds contradictory, but trust me.
    • ryandebny
      • Jan 2008
      • 37
      Gfi
      Thanks again you saved me alot of grief
      • spotty
        • Mar 2008
        • 11
        don't forget there needs to be two seperate circuits in the kitchen also.
          All kitchen outlets need be 20 amp. the only place a 15 amp breaker has use is lighting. any counterspace 24 inches or more needs an outlet. a free standing island needs at least one accessible outlet and not a surface (with the outlet face) flush with the counter surface. a tombstone outlet would do and an outlet mounted below the top on a side surface.
          • Speedy Petey
            • Nov 2006
            • 214
            Aany counterspace 24 inches or more needs an outlet.
            12" or more.
            Same goes for an island. A 12"x24" or larger island needs at least one receptacle.
