base board heat ??
  • armataz
    • Dec 2003
    • 47
    base board heat ??
    I have a cadet baseboard heater that dont want to come on.
    all the connections are tight. thermostats good,ground is good, heater is about 6 months old.
    I have 2 heaters on the same thermostat. and the second works fine. any one have any Ideas on what to check next?
    TAZ
    nuthing like being woken up at 12:AM to unstop some one elses toilet.
  • irregularjoe
    • Nov 2003
    • 176
    check the connections to the first heater again. Disconnect power and check continuity of the heater element.
    • armataz
      • Dec 2003
      • 47
      thanks I'll try that again. the heaters are looped together on the same circit with the thermostat on the 1st controling both.if that give any other info you might be able to use to give sugestions. I'm off to check the connections and continuity again.I'll check back later.TAZ
      • Jimmer
        • Oct 2003
        • 274
        Taz,
        At the heater that does not work, check at the opposite end to where you are making your connections. You should have the two leads connected using a Marr type connector. You might want to check that this connection is good.
        Good luck, Jim
        • armataz
          • Dec 2003
          • 47
          quote:Originally posted by Jimmer
          Taz,
          Good luck, Jim
          thanks jim, I found the problem. the heater had a bad heat sencer. I replaced it and the heater works fine now. thanks joe and jim for the sugestions some times it helps to have more than one person scratching their head.TAZ
