I recently purchased a duplex. Two main power panels (breakers) are in the basement. Wiring then goes to a master panel in either the upper or lower unit. For the upper unit, a sub-panel with one breaker comes off the main and feeds the air conditioning unit for the upper unit.
I found out that the line that goes to the air conditioner also powers the furnace, lights, and sump pump in basement. The 220 line that feeds the air conditioner was split with half feeding the furnace and the other half feeding the lights and sump pump.
I removed the fuse breakers and installed a 70 amp sub-panel. Questions?
Is it all right to leave it this way?
Should the A/C sub-panel and line feed only the A/C?
If they should be separated should the feed to the 70 amp sub-panel for the furnace and lights come off the main, the sub panel, or doesn't it matter.
Thanks for your help.
