pulling wire to a 220v stove
  • z85man
    • Nov 2008
    i just bought a used 14 x70 ft trailer.it had a gas stove.but,the ball and chain wants her glass top installed.the problem is there is no room in the breaker box in the trailer.so,i have to run a new line from the 200 amp breaker box on the pole to the kitchen.so,lets say i have to run at least 70' of wire.what size should i use and should it be covered?
    i will only bury about 12'.it has a 3 prong pigtail.thanks for any help.
    • 8747
    normally a mobile home has a 60 amp disconnect at the service pole which would mean a #6/4 Cord connection. look at the existing cord and see if you can make out any markings on it.
    • Speedy Petey
      • Nov 2006
      • 214
      Most newer trailers/mobiles have 100 or 200 amp services. How old is yours?
      What size is the panel? Most I have seen used small panels that can accept twin breakers. There may be room and you don't even know it.
      • z85man
        • Nov 2008
        hi
        the trailer is a 1970.but,it does have a 200 amp breaker.unfortunatly it doesnt have a spot left open.there is a 200 amp box on the service pole too.that is where im going to run my line from.
        • Speedy Petey
          • Nov 2006
          • 214
          Again, if you can let us know what kind of panel you have there may be room you can't see.
          It would not be legal to run a second line from the pole to the trailer. There must only be one feed.
          • z85man
            • Nov 2008
            the panel is a 200 amp service
            but,all the spots have been used by home wall lines or the heat pump or water heater.
              • 8747
              Find out the name of the panel and get back to us. If it uses full sized single pole breakers [1 inch spaces] you will need to remove four breakers, install two twin breakers and reconnect the circuits you disconnected to these twin breakers. This will open up a double pole breaker space. Now you will have a feed for your stovetop. Find out the wattage of the stove top and get back to us. we can figure out the wire size from this info.
              • davidg73
                • Jan 2008
                • 22
                then ou either use the twins like above IF you r panel is approved for such, or you install a subpanel next to the existing panel and move a couple things over to it as well as feed teh stove from it.
