switch/receptacle wiring with 4 wires coming out of the wall
  • rjeaton
    • Jan 2009
    I need a diagram 2hot 2 ground, I think.
    Thanks
    • 8747
    you got to find out what is the hot wire and which is the load. four wires means one hot, a return to the load, neutrals ( white) spliced together and applied to the nickel screw of the device. the break-away tab of the switch & outlet is not broken off.
    • Speedy Petey
      • Nov 2006
      • 214
      Can you tell us what exactly you are doing??? Some more detail would really help us in helping you.
