Tricky Switch
  • hacksawjimwagons
    • Feb 2009
    Tricky Switch
    Ok so....
    I've got a light to switch to switch to light...
    I've got the power feed on the kitchen light box...it is wired as followed...
    Hot feed to white switch/white feed to white fixture/black switch to black fixture/
    this operates my kitchen light apporpriately...
    the problem is, before i wired this new kitchen light, the kitchen SWITCH backed up to my living room switch, which in turn fed my living room light...
    with the new wiring, i'm not sure where to go from kitchen switch to living room switch to living room light...
    the more i read this, the more complicated it sounds, but hopefully someone out there can help me solve this riddle...i put it in the simplest terms that i know how...
    i'm off to offer my help in the heating and air section....
    thanks...
    Back to back wiring
    See if this diagram helps you. One feed from the kitchen box, jumpered to your back 2 back box for the living room light.
    • hacksawjimwagons
      • Feb 2009
      hey THANKS!
      its to soon to say if its helped me or not, but it LOOKS REAL GOOD....
      i'm going to try it out...
      i'll let you know how it works out...
