How to install a wall mounted swing arm lamp
  • jrvkumar
    Hi Gurus,
    I have a switch operated electrical outlet 2ft above ground. I would like to install a wall mounted swing arm lamp 2ft above the outlet.
    1. Can I connect the wiring to the electrical outlet (in parallel)? I will be using 60Watt bulb.
    2. I am new to this. My plan is to cut a hole 2ft above the outlet, run fishtape and pass wires to the electrical outlet and connect in parallel. Will this work?
    Thanks in advance,
  • Jimmer
    • Oct 2003
    • 274
    jrvkumar,
    Welcome to the forum.
    The answer is yes, you can tap into the outlet below.
    Good luck, Jim
