wiring combination and separate switch
  • levelhead
    • Apr 2009
    I need some wiring help. Referring to the attached picture, I want to control the sink overhead light with the combination switch and the left and right unercabinet lights with the single pole switch. The left and right undercabinet lights are fed by their own 14/2; they are not linked - but I want to control both of them with the one switch. I want the receptacle to always be hot. Is the wiring I drew correct? Any suggestions are greatly appreciated.
    yeah that'll work. if you are using metal boxes make sure you ground the boxes with the green or bare ground wires as well as the switch yokes.
    • levelhead
      • Apr 2009
      Thanks HayZee518. I am using a plastic old work box so need to ground it.
        nothing to ground to! unless you have a grounding clip at one of the cover locations.
