Dimmer causing buzzing
  • kriminaal
    • Oct 2009
    I'm installing some dimmer switches and have a floodlight installed in one.
    However there is a buzzing at every turn unless it is full on or off.
    Is it an improper bulb type that is causing this?
    Or do I have it wired incorrectly.
    I have it wired hot to hot
    neutrals bypass dimmer
    3 grounds together
    thanks
    the wiring is correct. the dimmer electronics create a square wave instead of a pure sinusoidal waveform. the output device is called a triac and it is gated [turned on and off] via electronics on its control board. they make an anti buzz coil but its a little pricey at $160 each!
