sub panel help
  • delirious
    • Dec 2009
    sub panel help
    Guys, I am wiring a sub panel in the garage but dont see a ground bus in the panel. I see the neutral bus but and not sure where the bare ground wires should go. I am using #6 wire. Two hot, one white (neutral) and one bare ground. I know where to hook these off of the main panel but not sure where the bare ground goes. I have two breakers in the sub panel. One wired for 110 with a 20 amp breaker and the other wired for 220 on a 30 amp breaker. Where do I attach the bare ground wires if I don't have a ground bus to attach it to.
    I don't think I am supposed to hook the bare ground on the neutral bus, right? Thanks for your help. I will try to get pictures.
    very easy - go to a big box store or an electrical supply house and ask for an AUXILLARY ground strip. They sell one that has about 12 openings - cost around three bucks. this installs in any free space inside the panelbox. the bare #6 goes here and all bare earth grounds.
    • delirious
      • Dec 2009
      Ok, I obviously need to remove the bare ground wire. The subpanel is not hooked to the main yet.
      Am I right, there is not place for bare ground unless I am missing something
      Question is in this lower photo, what are the two blocks with the pinkish looking screws? I am assuming they are to attach the neutral off the main leaving the bar for any additional neutral wires.
      That bar is the one that is for the neutral, correct? I don't see where it is grounded to the panel housing.
        the two landings to the right part of the panel will accept a bolt in aux ground bar. the neutral strip is not bonded to the panel enclosure in a sub-panel configuration. the red and black large diameter terminates on your main lugs in the sub panel. the pinkish screws may be larger diameter terminations for the bus.
          It also looks like you have double taps as well, you cannot use the breakers for multiple feeds. Code only permits one wire/breaker.
          like Hayzee says, the ground bar will simply screw onto the inside of the panel at a convenient location.
          • Handi-Women LLC
            • Feb 2008
            Your picture also shows that you have wired two separate circuits to each breaker. You should only protect one circuit with each breaker. You may need a larger sub-panel with more breakers to properly protect your wiring.
            • delirious
              • Dec 2009
              Thank you everyone. I will be adding additional breakers today along with the grounding bar. I hope home depot carries them, otherwise I will need to find an electrical supply. I recenlt moved to the area and dont know of one. Much thanks!
                from what I can see you have five spaces left for GE mini breakers or two full one inch spaces for a GE twin breaker
                  sniff....sniff...
                  (thanking myself....lol)
                  • delirious
                    • Dec 2009
                    Originally posted by pushkins
                    sniff....sniff...
                    Got all the material and I think I am good. Again, I appreciate the help.
                    img684.imageshack.us img684 6215 photo3ti.jpg put in the forward slash inbetween spaces. I wanted a follow up picture to help others
