we are having an addition built and they just finished the drywall and noticed in one of the corners where the cat5 box and the satbox is there is no outlet=bummer....so i went into the attic and saw that some of the new lines they did string for an adjacent outlet at the next corner in the room are totally accessible...so i measured 16" up from the floor and marked a place for an "old work" box for an outlet. I plan to place a junction box on one of the joist. i will cut one of the 14/2 lines, strip an adequate amount of wire , and do the same to a length of 14/2 that i will feed through the wall to the box.....returning the j-box,i will pigtail the 3 black wires with a red nut and the same with the whites and ground the box too! provided i clamp/anchor the wire in and out of the box and at required distances along the new service does this sound about right?
vincent
vpenoso@comcast.net
vincent
vpenoso@comcast.net
