Electronic Keyboard Power Supply
  • MOBoy
    • Oct 2006
    I found a 9V converter (adapter) which I want to use on an electronic keyboard. It states it is for use only with musical instruments. It fits the keyboard but when I measure the output voltage (neg inside, pos outside) it measures nearly 13V. Would it be safe to use?
    open circuit voltages are always higher when measured.
    • sam999
      • Aug 2008
      • 17
      ?! I just threw out a power supply because it was giving me too much volts..
      You're saying that was normal because it wasn't in-use?
      Oh man..
