Yesterday morning all was well. In the afternoon when my daughter went to her room she found out there was no power. Only one receptacle had power.
I have checked the GFCI outlets, there is only one in a bathroom that feeds
into another bathroom and they are working the way they should.
I have checked all receptacles in those 2 bed rooms including the light
switches and ceiling fixtures (one in each). Do not see burn marks anywhere
to indicate an arced short. All wires are snug. Did notice the last
receptacle in one of the bedrooms had a loose connection (2 wires and ground only). Replaced it just to be on the safe side. I believe that all
receptacles are in series connection with each other.
After I checked all outlets and replaced the receptacle that had power in the
morning, just in case, lost power in that too but noticed that one of the
circuit breaker (20A) in the main circuit box keeps tripping every time I
turn it off and then back on. When power to the entire house is out, there is
no problem with that breaker but the moment power is back, I can see a sudden fluctuation of power in the basement and breaker trips. I am sure that
breaker feeds power to the two bedrooms in question.
Not sure what else to do. All the testing today led me to believe that there
is a short somewhere that I can not figure out or the breaker has gone bad. I
can change the breaker myself but it is possible that there could be a short
elsewhere and breaker is OK.
Any advise will be appreciated.
