Is a 2-pole circuit breaker always 240volts or can it control two 120 volt devices?
2 Pole Breaker
I'm not an electrician, but I think you will find that if you use a 230 volt double pole breaker as two separate 115 volt circuits, and one trips, the other will stay engaged. Even though the breakers are side by side, they are still separate from one another and on different phases.Comment
Speedbump - I am an electrician and some breakers use a plastic tie-bar between the handles. Some like square D have an internal trip mechanism that opens both poles when one trips. The different phase correlation is only when the breaker is used on a 240 circuit.Comment
