I am in the process of installing a new digital controller on my old Mr. Spa. I've hit a wall in trying to decypher the wiring instructions on my main pump. It's a 110 volt, 2 speed Magnetek type SP. I'd never looked into the motor wiring, assuming it would have the expected connections for high, low, neutral, and ground, and that I would simply plug in the supplied power cord for the new controller and that would be it. Not so lucky. I've attached a scan of the wiring diagram from the motor for reference. So now I have three questions:
1. If this motor can be configured to accept the high and low outputs of the new controller, where do I put the red (low) wire, and what other jumper changes do I make? On this motor is is obvious that black (line) and white (neutral) will always go to 1 and 6 respectively.
2. If the motor cannot be configured to accept the red (low) output of the new controller it's not a problem to run with high speed only. (I have a circulator pump to service the heater and filter) If that's the case, I assume the left side jumper settings (w/o air switch) would be the configuration.
3. If possible, I'd like to understand how this motor was capable of two speeds with the old analog controller.
Thanks very much
Thanks very much
