Do Unused Appliances Use Electricity?
  • DarkKnight
    • 328
    Hi!
    I’m curious if leaving electrical devices like toasters or microwaves plugged in, even when not in use, still consumes power? Does it make a difference if the appliance has a clock or display? Thanks for any insights!
    TIA!
  • machinist
    Moderator
    • 386
    Yes, even when appliances like toasters or microwaves are off but still plugged in, they can consume a small amount of power, often referred to as "standby power" or "phantom load." This is especially true for devices with clocks or displays, as they continuously use power to keep those functions running.
    The difference might be minimal for individual appliances, but over time, it can add up. Unplugging them when not in use or using a power strip to easily disconnect several devices can help save energy.
    • DarkKnight
      • 328
      That’s really helpful, thank you! I was also wondering, what about mobile phone chargers? If they’re plugged into the wall but not actually charging a phone, do they still draw power too?
      • machinist
        Moderator
        • 386
        Yes, mobile phone chargers can still draw a small amount of power even when they're plugged in but not charging a phone. This is called no-load or standby power consumption. While it's usually quite minimal, especially with newer and more efficient chargers, it's not zero. Older or lower-quality chargers tend to use more energy just sitting idle. Over time, if you have several chargers or similar devices plugged in around the house, the energy use can add up. It's a good habit to unplug them when they're not being used or to plug them into a power strip that you can easily switch off. Even if the individual savings seem small, it can make a difference in the long run when it comes to reducing energy waste.
        • Annahmed
          • 223
          Whoa, I had no idea phone chargers still used power even when nothing's plugged into them! That’s kind of wild. Does that mean pretty much anything with a plug can be drawing power in the background, even if it looks like it’s off?
          • machinist
            Moderator
            • 386
            Pretty much anything that stays plugged in can potentially draw a little power in the background, even if it seems like it’s completely off. Devices with lights, displays, clocks, or any kind of “ready” mode, like TVs, gaming consoles, or even coffee makers with timers, are the usual suspects. But even simple things like phone chargers or power adapters without a visible indicator can still sip a bit of electricity while idle. It’s not a huge amount individually, but across a home full of gadgets, it can definitely add up over time.
            • DarkKnight
              • 328
              Do you think switching everything off at night would actually make a noticeable difference on the bill?
              • machinist
                Moderator
                • 386
                Absolutely! Turning things off at night can definitely make a bit of a difference over time. It’s a simple habit that helps cut down on unnecessary energy use, even if the savings aren’t huge right away. It’s more noticeable if you have energy-hungry electronics (like TVs with instant-on modes, gaming consoles, or desktop PCs). Using a smart power strip or just flipping off a surge protector before bed is an easy way to cut off power to multiple devices at once without the hassle of unplugging everything.
                • DarkKnight
                  • 328
                  Thanks for all the help. Definitely some great information to keep in mind!
                  • parker_james
                    • Jan 2026
                    • 9
                    Simple appliances like toasters typically draw no power when idle because they have no electronics active, while devices with clocks, displays, or standby electronics (microwaves, coffee makers) do consume a small amount of “phantom” or standby power. The draw is usually minimal per device, but it can add up across many plugged-in appliances over time.​
