Need Help Ceiling Fan Problems
  • SCAT3710
    • Dec 2010
    Good Evening,
    I am replacing my existing ceiling fan with a new one. However, I can only run either the fan or the light. Not both at the same time. what did I do wrong?
    With the light switch turned on, the lights power up and the fan shuts off. If I flip the light switch off. The fan will start up.
    Wires coming from my ceiling: 3 black all wound together, 1 white, and 1 white with electrical tape wrapped around part of it.
    Wires from the ceiling fan: 1 white, 1 black, 1 blue.
    I followed the instructions that came with the fan which told me to put the blacks and blue together and white to white and that constantly blew a fuse.
    I then attached the black to black, white to white, and the blue to the white with the electrical tape wrapped around it. With this setup I get the results like I have now (listed above).
    Please help.
    Thanks!!!! =)
    did your old fan have a remote control? normal wiring to a fan is black - motor, white - all neutrals, blue - lights. your existing ceiling wiring denotes a hot and neutral, a black downfeed to something else, another neutral [downstream] a black two wire to a switch with the return leg white [taped] so, connect all blacks together, [not the black and blue from the fan] splice the fan black to blue and then to the taped white. all whites together [inluding the white from the fan.]
    • SCAT3710
      • Dec 2010
      Thank you very much. I'll give that a try. =)
      No, my old fan did not use a remote. This new one does not as well.
