FAux floor painting.
  • ryandebny
    • Jan 2008
    • 37
    I'm refinishing my oak floors and want to faux stain a tiger wood or pickle barrel finish. Any suggestions... burning? ...stain colors?
  • Allison1888
    • Mar 2008
    • 42
    paintfloors
    Interesting idea. I've never tried painting a floor, but here's a link I found that has some tips. Of course, try it out on some sample boards or scraps if you can to make sure you get the technique down.
    http://www.oldhouseweb.com/stories/Detailed/12173.shtml
    • wvguy
      Painting, Decks and Fences Moderator
      • Apr 2007
      • 72
      sounds very interesting. If you are using paint on a floor follow couple things. first I would use a floor paint that way you know it is rated for horizontal surfaces. Only other thing I would recommend would be to use a water based poly so there would be no yellowing like with oil based.
      I would do at least 3 coats.
      good luck
      • tudor
        • Nov 2006
        • 62
        Here are some things I found: Creating Faux Wood Finishes
        Decorating : Graining / Combing : Faux Wood Grain : Home & Garden Television
        LIVING : Walls & Floors : Faux Wood Grain : DIY Network
        The building where I live in NYC has used a technique like this on a lot of the doors in its lobby area. They were originally metal and have had their faux wood grain surfaces touched up from time to time.
