Patina effect on walls
  • Annahmed
    • 223
    Hi everyone!
    What’s the best way to achieve a convincing aged patina effect on walls using faux painting techniques?
  • FatimaandAhmed
    • 343
    Hello!
    Start with a neutral base coat - something like beige or light gray works well as a foundation. Once that's dry, the real fun begins!
    The main technique is layering. You'll want to use glazes in different colors, applying them with sponges, rags, or even crumpled plastic wrap. Start with darker shades and work your way to lighter ones. This creates that mottled, time-worn effect we're after. Color washing is another cool method. It's about diluting your glaze colors and brushing them on in random strokes for a softer look.
    Pro tip: use colors you'd actually see in aged materials - think rust reds, mossy greens, soft blues. And remember, the key is imperfection. Real patina isn't uniform. For an extra touch of authenticity, you might try adding some crackling medium in spots or lightly sanding areas to reveal bits of the base coat.
    It's all about building up the effect gradually. Take your time and have fun with it!
    • Annahmed
      • 223
      Thanks for sharing this!
