Hi everyone!
Metallic and iridescent finishes are a great way to add a subtle shimmer that changes with the light and really lifts a room’s look. Here’s a simple guide to get started:
What You’ll Need:
Quick tip: Practice on a small board first and go slow with the glaze to avoid streaks!
Adding shimmer with metallic or iridescent finishes is a fantastic way to bring depth and interest to any room. It’s all about layering gently and paying attention to how the light plays on the surface for the best effect.
What You’ll Need:
- Base paint in a neutral or dark color
- Metallic or iridescent glaze (you can find these at most paint stores)
- Soft brushes or sponges
- Clear topcoat to protect your finish
- Prep the Wall: Clean and smooth the surface. A good base coat helps the shimmer pop, so paint your base color first and let it dry well.
- Mix and Apply the Glaze: Mix your metallic or iridescent glaze with clear glaze if needed. Use soft brushes or sponges to apply thin layers, working in small sections.
- Build It Up: Add a few layers, letting each dry a bit before the next, to get a nice depth and shimmer.
- Check the Lighting: Look at your work under different lights – natural and artificial – to make sure the effect looks just right.
- Seal It: Finish with a clear topcoat to keep it looking fresh and protect your work.
