Cleaning Hardwood Floors
  • AshRae
    • Feb 2026
    • 10
    What's the actual right way to clean hardwood floors? I don't think I am getting them clean and am worried that if I use anything strong I will ruin them. What is the go to for cleaning them? Is it vinegar, hot water, what?
    Thanks in advance!
  • floorman
    • Jan 2005
    • 61
    Depends what finish is on them but assume polyurethane unless you know otherwise. Skip anything with vinegar, ammonia, or wax — vinegar's acidic and eats the finish over time, wax builds up and gets slippery.
    Use a microfiber mop, barely damp, with a cleaner actually labeled for hardwood (Bona is fine, don't need anything fancy). Never wet-mop, standing water gets in the seams and swells the boards. Vacuum or dry-sweep first so you're not grinding grit into the finish. That's it, nothing complicated about it.
    This is the kind of mop head:
    Bona Hardwood Cleaner:
    Floorman
    floorlayers union local 1310
