After wobbling on the lower flight of basement stairs, I replaced the stringers and treads in our small 1920s dutch colonial. For the stringer, I used a 7 foot length of treated 2 x 10. (We have had some minor flooding.) I copied the original design by using blocks attached to the inside of straight sided stringers to support the treads. I attached 10 inch lengths of 2 x 4s with 2.5 inch decking screws (suitable for treated wood). Six screws for each 2 x 4. Deck screws are very convenient as they screw in easily with a drill. After I completed the job, I was removing a real wood screw from some scrap and was reminded how stout a wood screw is compared to a slender deck screw. I thought that deck screws are meant to keep deck boards down as opposed to supporting something vertically.
Did I "screw" up by using deck screws instead of wood screws to attach the tread supporting blocks?
