ceramic tile in basement
  • jvtran
    • Oct 2004
    • 22
    i plan to install ceramic tile over concrete basement floor. how should this be done? do i need cement backer board? if so how thick and how should i fasten it to the concrete floor?
    can i just lay the tile on top to the concrete without backer board?
  • floorman
    • Jan 2005
    • 61
    Sorry it took so long to respond.You first need to go over the floor and check for cracks,if you have any they will need to be isolated with some sort of membrane.While there check for flatness as well it will need to be pretty flat for tile,if too rough you will need to level the floor with something.
    Please get back to us and we will get you through this.[8D]
    Floorman
    floorlayers union local 1310
    Floorman
      My dad put vinyl tile directly on the cement floor AFTER sealing with a concrete sealer. Because this is ceramic directly over concrete, I would used a concrete "binder" to assure bonding of the quickset mortar to the existing concrete. My shower pan was custom built and used a sort of dry mortar for the floor so it had necessary "teeth" when applying the quickset to it to set the tiles into.
      • SSN596
        • May 2005
        • 136
        It is always a good idea to use an anti-fracture membrane when putting tile on concrete. Use either an actual membrane, of on of the new brush-on types like RedGard.
        • jvtran
          • Oct 2004
          • 22
          What about a cement backer board? Can I place 1/4 cement backer board on top of the concrete anchored down with tapcons screws and then tile right over that?
          Do you see any problems with that?
          • SSN596
            • May 2005
            • 136
            Putting backer board on a cement floor is overkill. Way too much work. If the cement floor surface is damages, patch as necessary. Then use the membrane, applied per manufacturer instructions.
            • jvtran
              • Oct 2004
              • 22
              ok the local hardware store sold me some self leveling concrete and told me to use thinset on top of the concrete and then tile right over that.
              it was mentioned on a earlier post touse a membrane. what are membranes usually made of? rubber? how do i get that to stick to the concrete?
              • SSN596
                • May 2005
                • 136
                There are a number of different membranes. Some are a stretchable fabric, one ( RedGard ) is liquid applied with a roller. Follow directions about adhesion.
