I am looking for any help or guidance that can be provided on removing a cracked/split stair tread in my 1920s colonial. It appears that several steps have split along the glue joint line and I would like to repair or replace these. I am hoping to remove the treads without destroying them in the hope of re-ripping, re-jointing and re-glueing them and saving as much of the original wood as possible.
The step is recessed in a mortise cut into the wall-side stringer. A dado on the underside of the front of the tread fits over the riser but I do not see anything holding the back of the riser down other than nails into the stringers. I removed the balusters and used a reciprocating saw to cut through the nails that go through the top of the tread but I can't seem to get the tread to move very much (I can lift the baluster side of the tread 1.5" or so, but that is it. I do not have access to the underneath of the stairs.
Any suggestions?
Thanks in advance,
R
Any suggestions?
Thanks in advance,
R
