I am going to be installing tile on my basement floor. There is not a moisture problem. I am going to scrape up all of the loose paint. My question is: should I use a floor etcher to make the surface abrasive?
Installing tile on basement floor
Tags: None
The simple answer would be "yes". The floor has previously been painted and no matter how hard you scrap the paint back you will not get it all. A simple and cheap concrete cleaning/prep. product available at any hardware store would do the job.
Make sure you read the directions and ventilate as best you can, most of the cleaners have some level of toxicity to them.
