how to cut backer board?
  • pbc
    • Apr 2008
    • 34
    I'm installing a new floor in a downstairs bathroom on the existing joists. The old floor was completely removed and will be getting 3/4 plywood and then backer board on top of that.
    Aside from cutting the backer board to fit the whole floor area (5x9) I will need to cut holes for the shower drain, toilet and sink.
    Is there a hole cut tool for cement backer? And what about cutting to size?
    use a carbide holesaw - the price will knock yer socks off but its the best way
    • traffic_sucks
      • Dec 2008
      I've never tried this, but I read in a book where you can drill a series of 3/16" diameter holes around the perimeter of the hole and punch out the hole with a hammer. I imagine a masonary bit would be necessary.
        Get yourself a masonry blade for your circular saw, that's the easiest way or you can by a backer board scoring knife for about $10 at Lowe's/Home Depot.
        If you use the masonry blade in an old circular saw, cut a series of lines in the middle of your circle from one side to the other then you can simply score the circle perimeter with a sharp (not for long) Stanley knife and bend the pieces out.
        Ideally I use a Rotozip with a masonry blade to do smaller holes.
        NOTE wear a mask if your using the saw.
        • www.mikebocktile.com
          • May 2009
          • 5
          Backerboard Shear
          If you cut the backerboard with a circular saw, wear a respirator mask and use a fan to blow away the cement dust. Breathing it is easy at first. Somwhere in the middle of the night your throat will start hurting and bleeding. I use a backerboard shear, they cost about $300 and do a real clean and relatively dustless job. Home Depot and Lowes sometimes have a board called TILE BACKER board. It is gyspum based... has a rough blue colored waterproof front, can be cut with a knife just like sheetrock, however it will hold up much longer than Purple or Green Board.
          • ceramictilepro
            • Oct 2009
            • 16
            hardie backer cutting
            any power tools will create alot of dust which nasty stuff...wear a respirator and cut it outside.
            a makita 4" grinder makes quick and dusty work of this
            ceramictilepro
            • AshRae
              Cleaning Hardwood Floors
              by AshRae
              What's the actual right way to clean hardwood floors? I don't think I am getting them clean and am worried that if I use anything strong I will ruin them....
              08-11-2026, 01:17 PM
            • amibar
              How to do a Proper Carpet Cleaning
              by amibar
              The first step to a good carpet cleaning is to know the type of carpet you have in your house. Different types of carpet need different ways to be cleaned....
              05-03-2021, 11:38 AM
