Condo Soundproof Question
  • MikeS
    • Oct 2009
    Hi everyone,
    I own a first floor condo and recently, the owner of the unit above me decided to install wood floors as he was having new tenants move in. The building is flexicore, so I was not too worried at first. However, I can now hear every footstep, conversation, cough, laugh, etc. I asked to owner to maybe spring for some throw rugs, but he won't cause it is not in their lease. I asked our Association President if 2nd floor units can have wood floors and he says they can. (I'm still looking into that although.) Anyway, I also offered the owner that I would split the cost to have carpet installed, but he has not gotten back to me. To be honest, it is slowly driving me crazy. The tenants are not doing anything wrong, they are not loud or anything. I was planning on trying to sell my condo next year and this is a huge problem for when I am showing it to possible buyers.
    Does anyone have any input on things that could help this? I appreciate any help. Thanks in advance.
  • The Builder
    • Aug 2009
    • 65
    They manufacture soundproofing boards for different sound grades and noises.You also can install an extra finish shuch as a thicker sheekrock for the ceiling.
    • chino
      • Oct 2009
      • 15
      You should check your CC&R's because many multi level condos have rules for these sorts of things. Specifically, my condo is a 3 story and you can not have hard wood floors or stone tile if you have people living below you. So basically only people on the ground floor can have hard wood or in my case, our unit is above a garage so we are ok.
      • glazerandsachs
        • Oct 2026
        Checking the CC&Rs is the right first move — in Florida, most multi-level condo declarations restrict hard flooring above living spaces or require a specific soundproofing underlayment, and the association can enforce that rule. Put your complaint in writing to the board, cite the exact declaration section, and keep a log of dates and times the noise occurs. If the board drags its feet, a Florida condo association attorney can review your documents and lay out your enforcement options.
        • dntreecareinc
          • Oct 2026
          • 9
          That sounds frustrating, especially since the tenants themselves are not being loud — it is really about how sound travels through the floor assembly.
          A couple of things that often help in this situation, in addition to checking the association rules that others mentioned:
          First, put the request to the board in writing and keep a simple log of when the noise is most noticeable. A written record makes it easier for the board to follow up than a verbal conversation, and it helps if the upstairs owner later agrees to add rugs or an approved underlayment.
          Second, on your side of the ceiling, the biggest gains usually come from adding mass and sealing gaps, rather than from a single thin layer. For example, a second layer of drywall on resilient channel, with acoustic sealant around the edges and around any light fixtures or vents, can reduce both footsteps and voices more than just repainting or adding a standard ceiling. Check for any open gaps where pipes or wires pass through, since sound leaks through those small openings too.
          Third, ask the board what flooring and underlayment standard applies to units above occupied space, and whether the upstairs installation was checked against that standard. If an approved underlayment was not used, that is a practical point to raise with the board and the upstairs owner, without making it personal.
          It may also be worth keeping notes for a future sale, so you can show what steps were taken and what the board said. That paper trail can be useful even if the noise improves only gradually.
          Hope you get some relief — this kind of impact noise is common in older condo buildings, and it usually takes a mix of the association process and a ceiling-side improvement to make a real difference.
