Many people don’t know to install bamboo flooring. The points below may help your installation work:
1. Open the package in the installation area at least 4 days before the installation to make sure that bamboo flooring be used to the temperature and humidity.
2. Keep the installation space dry and flat. Paint moisture proof lacquer or fit underlay with PE film on the installation space.
3. Choose ceiling joist with hard and dry wooden wood plank. And the ceiling joist must not be wormy. Fit the ceiling joist to the subfloor and make it with multi cross appearance. The size of the cell should be around 20cm*20cm. Make the surface of ceiling joist flat. Keep at least 5 pcs of ceiling joist under plank.
4. Keep 0.6mm gap between each bamboo plank. Fix the bamboo plank on the ceiling joist with nail. The knock angle is should be around 45 degree.
5. The short side of the bamboo plank should head the door to have a better look.
6. Keep a 12mm wide gap between bamboo flooring and wall for the expansion purpose. Paint the cut end with varnish for the moisture proof purpose.
