Several years ago a contractor installed a vinyl (sheet) floor in our bathroom. Where the flooring edge meets the tub enclosure was caulked (filled) with a white material which is now starting to crack? Several Questions.. (1) what material would I purchase to replace this cracking white joint sealant and (2) is there an easy way to remove the old material without damaging the flooring / tub or does it have to be removed?
Vinyl Flooring / Fiberglass Tub Enclosure
You need to remove any of the existing caulk that is loose or cracked, the best way is with a flat blade like a little scrapper or if your really careful a sharp flat razor scrapper.
To reseal it with 100% silicone, you can get at Lowe's/HD a 3 hour dry product, so you can use the bath that night if you need.
