I have a small shop (approximately 8 ft x 16 ft) that I use for building models, working on electronics, and other small projects. Currently the floor is a continuation of a brushed surface concrete carport slab. I want to make it look better and easier to kee clean. Looking for suggestions on a flooring material.. So far I have considered (1) laying asphalt colored tile but I don't know if I can do that directly on rough concrete, (2) using that epoxy material with color chips in it, again I don't know how it will adhear to bare concrete and (3) colored rubber matting and cutting it to fit around everything. Any suggestions what I mught use keeping in mind that I don't want to spend a fortune on the job but want something that looks nice, easy to clean and is brighter than concrete.
Floor material for small hobby shop??
Why not use the rubber mats that interlock together. I use them in my workshop (mainly at the bench), comfortable to stand on and I either broom them off or use the blower vac.
If the slab isn't too rough, you can put vinyl composition tile down very inexpensively. I think the last time I bought it I paid around 45 cents a square foot.
If it is too rough and you wanted to put in VCT, you could skim coat it with a cement-based patch, then VCT.
VCT is very easy to install, very durable, and easy to clean. I have it in my garage and it works great.Comment
