I've got what hopefully amounts to a simple question...
About three weeks ago I noticed that the circulator pump (BG-100 series) on my 35 year old boiler system was cycling on/off in short bursts, like 5 seconds at a time. If I recall correctly, I remember that the pump used to run the entire duration when the boiler was fired up, then remained on for a few minutes afterward.
The boiler has not been run in a couple of weeks due to warm spring weather. Last night was a bit chilly, so I turned up the thermostat only to find that the boiler wasn't kicking on (just total silence after the thermostat call).
I checked the circuit board to find that the breaker had tripped (its a dedicated breaker). So I turned it back on and the system fired up without delay, circulator pump and all. After running about 5 minutes, everything shut down again - the circuit had tripped.
I turned down the thermostat, and reset the circuit. All was ok. I turned up the thermostat and it clicked as usual. But then, I heard a loud click at the furnace right at the time the system would fire up, and the circuit was tripped again.
Is this possibly a symptom of a bad circulator pump motor? Are there any checks I can do to better diagnose the issue?
If it is the pump motor, do I replace just the motor, or switch the entire unit to a TACO 007 or something. Its a 2500 sqft house with 2 zone baseboard heat. Mind you, the place is for sale, so I don't want to spend a ton on a fix. I'm pretty handy, but don't want to open Pandoras box with this 35 year old boiler. Also, I don't think I have shut-off valves on both sides of the pump.
Thanks in advance for any advice/input! Jason
