Hello,
I have a 1950 Cape style home in Boston. It only has soffit vents on one side of the pitched roof and has a gable vent on each end. I had a new roof put in 3 years ago and they added a ridge vent. I then had an insulation audit and they sealed and blew in insulation over the existing insulation in the attic. (They also blocked the soffit vents with insulation.)
- What should I do??
1) Leave it alone
2) Unblock the insulation blocking the soffit vents (again there are only soffit vents on one side of the house (pitched roof).
3) Block the Gable vents (but what happens when snow covers my ridge vents all winter). It is extremely difficult to get into the attic, can I cover the gable vents with plastic on the outside.
Most importantly I have a newborn and want to make certain the air quality is good. As well as extend the life of my asphalt shingles.
Thanks Very Much! Jake
1) Leave it alone
