HVAC leak
  • HVAC leak
    Hi everyone! I am new to this forum. I bought a newly built house 4 years ago with central air. Recently the A/C stopped working so I hired an HVAC tech to come take a look into the issue. I was told that there was no freon so he helped me recharge the unit. Less then 2 weeks later the A/C was no longer working. I called the tech back and he said there is probably a leak and that he would need to put in dye with a sealant and recharge the system again.
    I am uncomfortable doing this because I feel that the tech should do this procedure and follow the lines to see if there is a leak since the system is pressurized. However he told me to call him if this does not fix the issue. So before I get him to do this I followed the lines from the A/C unit on the outside all the way into the air hanger. I was hoping to find some oil left behind by the leaking freon. No luck there. However, I did notice that the metal threaded cap on top of the high side valve (where you attach the gauges to) to be loose enough where I can twist it off. Also the black cap that protects the valve is missing the o-ring on the inside of the cap. Will this cause the freon to leak? Do you know what that part is called? Thanks for taking the time to read this!
    that proves the valve stem packing is leaking freon. the gauge cap on the access valve normally is a flared fitting. the stem cap has an O ring inside. the tech should have pressurized the system with nitrogen then tested for leaks. after that he should have brought the system into a deep vacuum to see if there were any leaks. the system should have kept a vacuum for 24 hrs. if no leaks, recharge the system using a charging cylinder.
