Central Heating not turning off
  • Almost Able
    • Aug 2011
    I have central heating/air conditioning with a mercury thermostat. When I turn on the air, it turns on and off as it should relative to the temperature setting. When I turn on the heat, it fails to shut off even when I flip the switch to off, I have to turn the switch to AC then to off for the system to stop. I've turn the breaker off for about half an hour then turned it back on in hopes of resetting the system but the heat isn't shutting off once the temperature is reached.
    the old round honeywell thermostat has a heat anticipator under the brass plastic cover. look for a copper colored pointer and a scale of numbers. match the pointer to the burner current rating or if it is gas, the gas valve current. usually printed on the valve. this will lessen the burner short cycling.
    • Almost Able
      • Aug 2011
      It's not that old of a thermostat. It's GE and is rectangular shaped. The temperature setting on top with the reading on the right, and further to the right is the Heat/Off/Air, etc. Under the cover are two bars with mercury in them, one positioned atop the other.
        the mercury bulbs are just switches that have to be mechanically operated by some means - a bi-metallic coil for temperature, a taut plastic membrane and a linkage for humidity. electronic thermostats use a solid state switch called a triac. a magnetic reed switch is mechanical and can be actuated by a common magnet or a coil of wire wrapped around the switch. the reeds are vacuum sealed in a glass bullet.
        • paul52446m
          • Nov 2009
          • 690
          We need to see if the problem is in the furnace or thermostat. Turn the heat on, go to your furnace and disconnect the white coming from the thermostat.
          If the heat stops then the problem is not in the furnace. Try this first.
          Why are you using a two stage thermostat?
          What color wires are on the stat and what post do they hook to? and what do they hook to in the furnace? Paul
            Laser 730 over firing
            by hawkins111
            Has anyone had an occurrence of a Laser 730 or 731 over firing?
            The top of the heat chamber and the heat exchanger glow red on high when this occurs....
            11-12-2024, 10:29 AM
          • 911Restoration
            Fireplace Woes
            by 911Restoration
            09-22-2026, 03:14 PM
