Coleman DES 80 furnace issue
  • Brijoe00
    • Dec 2011
    Hello-
    I am hoping someone can help me out on this. I have a Coleman DES 80 gas furnace. I have the thermastat set at 72 but the house will get really cold down to like 65 and the furnace will not come on. The vent motor will be running, but the furnace will not ignite and there is no hot air blowing nor the blowing is running. If I turn the furnace off and on a few times it will eventually ignit and come on. Thinking I need a new electronic igniter assembly? Any suggestions would be appreciated.
    Brian
  • paul52446m
    • Nov 2009
    • 690
    Originally posted by Brijoe00
    Hello-
    Brian
    What type of igniter assembly do you have? glow bar or spark. Is this a 80 plus or 90 plus furnace?. A few pic. would help. Paul
    • Brijoe00
      • Dec 2011
      Well the furnace says Coleman D.E.S. 80 but it does not say plus on it and I dont see anywhere that it says des 80 plus. I am not sure whether this is a glow bar or spark. If I had to guess I would say a glow bar as I do not hear a click click before igintion as I would assume you would hear if it were a spark but I could be wrong. I included a picture of the furnace, the blue and grey wires on the bottom go to the HSI as indicatied on the wireing diagram. The hsi wires go into the burner box where I assume the HSI is located.
      • paul52446m
        • Nov 2009
        • 690
        Yes it is a glow bar. Would it be possible to show us a wiring diagram. The pic. does not show everything. Paul
        • Brijoe00
          • Dec 2011
          Here is a picture of the diagram, Hope it came out ok thats the best I could get it.
          • paul52446m
            • Nov 2009
            • 690
            I got your diagram ok. on the bottom of the diagram its list the controls.
            I can't read the numbers Can you mark them with a ink-pen, and also mark them up in the diagram with a pen. They are too small on that yellow paper.
            Paul
              Laser 730 over firing
              by hawkins111
              Has anyone had an occurrence of a Laser 730 or 731 over firing?
              The top of the heat chamber and the heat exchanger glow red on high when this occurs....
              11-12-2024, 10:29 AM
            • 911Restoration
              Fireplace Woes
              by 911Restoration
              09-22-2026, 03:14 PM
